vcSelectProductsStatement
Statement that filters product types from a given list variable to a new list variable.
FiltervcProductFilterRGets the filter.
MaxCountPropertyvcExpressionPropertyRGets an expression property that defines the maximum number of accepted products.
ProductVariableNameStringRWGets or sets the name of the input list variable to filter from.
SplitVariableNameStringRWGets or sets the name of the output list variable to filter to. This variable will be created if it does not already exist.
demoteFromCombinationFiltervcProductFilterNoneDowngrades back to filter, filter count must have 1 or 0 filters.
vcProductFilter: The modified filter.
TypeError: When the filter is not a CombinationFilter.
TypeError: When CombinationFilter has more than 1 sub-filters.
promoteToCombinationFiltervcProductFilterNoneUpgrades current filter to combination filter.
TypeError: When the filter is already a CombinationFilter.
replaceFromvcProductFiltervcStatement statementSets filter from other container.
statement (vcStatement): The statement to replace the filter from. Has to be a statement with a filter container.
AttributeError: When argument is a statement without a filter container.
setFiltervcProductFiltervcProductFilterType filterTypeSets to specific filter.
filterType (vcProductFilterType): The type of filter to set to.
vcProductFilter: The new filter.
AttributeError: When the argument filterType is ProductType.
NameParametersDescription
OnFilterChangedNoneTriggered when filter is changed.
